Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - popping noise from cylinder opening
Old 10-01-2012, 08:03 PM
crownver crownver is offline
The plug hole is down inside the opening you mentioned. Opening goes through the rocker cover. If the threads on the plug are hooped there's a good chance the threads in the head are gone too. If that's the case, as Ruthlessmr said, you'll have to have the hole helicoiled. Don't think that can be done without pulling the head off.
The Following User Says Thank You to crownver For This Useful Post:
saltbob (10-01-2012)
