Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - popping noise from cylinder opening
Old 10-02-2012, 03:09 PM
sbchevfreak's Avatar
sbchevfreak sbchevfreak is offline
Licenced Automotive Technician
2001 triton, uses a conventional plug. These were known for this issue. DO NOT USE A NORMAL HELI-COIL! They will not hold. this needs a "Time-Sert" style solid insert. I have done them on the truck, is possible, but time consuming. once the 'sert is in, usually no more issues, if done correctly, but I have seen them blow out, at which time the head needs to be replaced.
The Following User Says Thank You to sbchevfreak For This Useful Post:
saltbob (10-02-2012)
