popping noise from cylinder opening - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-01-2012, 07:26 PM
saltbob's Avatar
Last journal entry: Iembarrassed about starter problem!
HI everyone saltbob here I have a F-250 5.4 Triton engine 2001 appx 122000
miles on it all of a sudden while driving it started makeing a very loud popping
noise first thought I had a blown tire but it would get louder as engine rev.
I opened the hood it was jumping fire on one cylinder large hole where spark
plug goes, the plastic cap and long spring was off spark plug, the rubber boot
was split. the spark plug was on top of the motor with ehd of spark plug bent
where you would you would set the gap I"m old school and don"t know what
going on because there is a large deep hole where spark plug goes, I can"t
find any where to screw a new plug in allso plug threads on end looks bad If
anyone in HOT ROD LAND have a clue to what happend please let me know. I
have 2 cars 1 truck both cars need transmissiom, I"m almost down to walking.
SALTBOB Thanks hot rod people
Old 10-01-2012, 07:58 PM
i think these are known to pop out plugs
you have to have a special time cert helicoil
dont take them out hot let it cool
The Following User Says Thank You to Ruthlessmr For This Useful Post:
saltbob (10-01-2012)
Old 10-01-2012, 08:03 PM
The plug hole is down inside the opening you mentioned. Opening goes through the rocker cover. If the threads on the plug are hooped there's a good chance the threads in the head are gone too. If that's the case, as Ruthlessmr said, you'll have to have the hole helicoiled. Don't think that can be done without pulling the head off.
The Following User Says Thank You to crownver For This Useful Post:
Old 10-01-2012, 08:15 PM
BOBCRMAN@aol.com's Avatar
These motors are known for that problem. Or blowing the plug centers out leaving the threads siezed to the head.
Yes they can be heli coiled on the vehicle. Not the best thing. But, I used to do it on the local power companies vans. They wouldn't pay to have it done off the vehicle. I made a tool to get the plug threads out. Doing the heli on a 5.4 in a van is a real adventure.
The Following User Says Thank You to BOBCRMAN@aol.com For This Useful Post:
saltbob (10-02-2012)
Old 10-01-2012, 09:47 PM
as has already been stated, the ford modular motors have a bad habit of that and ford doesn't seem to see it as a problem.
if it were mine, i would pull both heads and have a reputable shop put inserts into all of them because its just a matter of time before more do the same.
save money and future headaches, fix it right hlathe first time.
The Following User Says Thank You to Plaintoast For This Useful Post:
Old 10-01-2012, 10:41 PM
those engines had a pressed on ground electrodes on the plug as well. lots of them get repaired because when the plugs are removed for replacement the pressed on ground comes off the plug and stays in the head. napa has a special tool for getting the electrode out (and there are lots of posts on the net about how to repair that problem), maybe they also have a kit for installing threads that were damaged. either way, always change the plugs on a cold engine or trouble will come looking for you.
grab a mirror or borrow/rent a snake inspection camera and take a look down the hole where the plugs go in (I hear harbour freight has an inexpensive camera, try to get the largest viewing screen you can find). you should be able to see if there are threads left in the head. also, did the ground electrode come along for the ride with the plug, or did it stay in the head? did it pull the threads out for the coil mounts? is the coil damaged? I have changed plugs on a few of these engines and never had a problem yet, but I have had lots of trouble with coils that worked fine when the vehicle came in for plugs, but misfired right after they were removed for plug access. not exactly cheap either. if you install new plugs always use anti sieze compound on the threads.
keep us posted and good luck
The Following User Says Thank You to dsraven For This Useful Post:
Old 10-02-2012, 04:49 AM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
Yup.
Dorman Products makes a spark plug rethread kit that will get you out of this situation relatively inexpensively.
Dorman # 42025
Also available at your local NAPA store in the Balkamp/OE Solutions product line under part # OES 6003248. (Sells for $83.49 CDN here in the Calgary area)
Just to clarify the fact that there are two diiferent types of plugs used on Triton engines, depending on the year of the vehicle.
The plug that fits YOUR year/make/model is what I would term a "conventional" spark plug.
I'm an NGK fan, so the PN for a platinum plug is 3403
This Dorman kit uses an extended spark plug similar in design to the newer (i.e.2005) Triton engines.
CHA 7989
For these engines I actually recommend the Champion "Truck Plug" because it is a one-piece design, that eliminates that broken chunk that gets left behind problem referred to earlier in this thread.
If / when you decide to replace the rest of these plugs, make sure you spray them with copious amounts of the best penetrating fluid that you can get your hands on, and let them soak overnight. CAREFULLY remove the old plugs, and inspect the threads to see if they are pulling aluminum out of the heads. Use anti-seize on the new plugs to prevent galvanic corrosion.
Here's a video:
Best of luck, and hope this helps!
The Following User Says Thank You to 66GMC For This Useful Post:
Old 10-02-2012, 03:09 PM
sbchevfreak's Avatar
Licenced Automotive Technician
2001 triton, uses a conventional plug. These were known for this issue. DO NOT USE A NORMAL HELI-COIL! They will not hold. this needs a "Time-Sert" style solid insert. I have done them on the truck, is possible, but time consuming. once the 'sert is in, usually no more issues, if done correctly, but I have seen them blow out, at which time the head needs to be replaced.
The Following User Says Thank You to sbchevfreak For This Useful Post:
popping noise MosinNagant Engine 2 05-10-2010 04:11 PM
'98 cherokee frnt differention popping noise newdad1 Transmission - Rearend 29 08-04-2009 09:48 AM
popping noise capn_crunch4x4 Transmission - Rearend 1 05-19-2006 12:30 PM
popping noise... 97Z28 Suspension - Brakes - Steering 8 02-20-2006 04:05 PM
Overefficient cooling system and popping noise. TVR383 Engine 8 11-09-2005 08:17 PM
