pops back through carb - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-08-2003, 07:32 PM
I have a 87 Ford 460 motorhome. It had been sitting for awhile before I got it. I put a new carb, points, timing chain & gears, fuel pump etc. on it. I tried to start it and it gave one big backfire out of the exhaust. It bent several push rods. I replaced them all with new ones. It now starts and runs well but pops through the carb under load. Does anyone have any idea of what else I can do or check. I have tried everything I can think of including checking the timing (OK). I put a vacum gauge on and at a higher RPM it says "late valve timing" on the gauge.
Thanks.
Old 11-08-2003, 07:41 PM
DoubleVision's Avatar
By the sound of it, i`d either say the cam is worn out, the carbs too lean, or the ignition system is out of whack. first I`d check would be the cam, snatch the valve covers and start it, check the motion of the rockers, if you see one that`s barely lifting the rocker arm, you found the problem. if they check out okay, pull a few plugs and see what color they are, if there white it indicates a lean mixture. I didn`t know 87 model motor homes still had point ignitions in that year, but if it does have points, I`d can it and get a electronic, points are a waste of time on any level compared to electronic. run a spark test and see what color the spark is, if it`s yellow, it`s weak and there`s a component somewhere in the ignition system that`s bad. also check the spark timing, make sure it`s advancing off idle.
Old 11-08-2003, 07:45 PM
Thanks for the quick reply. I'll try your suggestions out tomorrow. Take care.
Gus
Old 11-10-2003, 08:52 PM
Old gasoline (which may not burn very well anyway) will sometimes coat the plugs with a conductive residue, which can also be a cause of this.
Old 11-10-2003, 09:10 PM
HARVICKx29's Avatar
2 much power is almost enough
hey, this may sound stupid and i think i already know ... but.... how do you do a spark test?
Old 11-11-2003, 08:32 AM
Wrencher's Avatar
DV's probably on the money," also check for a broken spring" if not, check the point dwell 30, or gap .015, and reset timing.
