Por 15 - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-01-2011, 07:01 AM
BEC's Avatar
BEC BEC is offline
29ster
Last journal entry: Rear suspension
Por 15
Getting ready to coat the inside of my Roadster and wondered what is the best thing to use? MY brother used POR 15 on his 34 and spent 2 weeks trying to remove it from parts of his body (his and the car) when he was done. Any suggestions as to the best finish before upholstery?
Old 02-01-2011, 08:49 AM
boatbob2
painting with por-15
Hi,i have had NO luck using por-15.i personally recommend using epoxy zinc chromate.since its inside the car,you can either brush it,or use a small roller.
Old 02-01-2011, 09:15 AM
1971BB427's Avatar
If you had or have rust issues POR15 is a great product. If everything is clean and new it's not a great choice. Use a good paint, and don't spend the extra for POR15.
Old 02-01-2011, 09:19 AM
BEC's Avatar
BEC BEC is offline
29ster
Yeah that's what i thought. All new Sheet metal now but I just wanted something durable and easy. I intended to paint the bottom body color but inside and under the sticky stuff I wanted to protect and perhaps sound deaden the panels with some good stuff.
Old 02-01-2011, 09:24 AM
1971BB427's Avatar
If you're looking for sound deadener then most paints wont give you any. I went with Home Depot sound deadener, as the Dynamat stuff was just crazy priced. The stuff at Home Depot was $15 for a 1'x15' roll and it's foil backed, self adhesive, with dense foam. No asphalt products to stink in it. I found it in the heating duct dept.
Really cut noise in my Austin. I drove it with no interior before this, and after getting just the deadener in it made a huge difference. Once carpet and door panels were in it was even better!
Old 02-01-2011, 09:26 AM
BEC's Avatar
BEC BEC is offline
29ster
Sound Deadener
Great advice on the Home Depot stuff
Old 02-01-2011, 10:54 AM
327NUT's Avatar
Here's something else to try, do a search on this site for..."alternative to lizardskin" it's basically a DIY on coating the interior of your car with a roll on/brush on material thats an insulation/sound deadener.....good reading.
Old 03-04-2011, 03:36 PM
55chevypanel's Avatar
actually por15 sell a metal prep you can spray on bare metal to create a <i believe, a zinc oxidation that the por 15 will adhere to beautifully . if it will be exposed to UV / sunlight there is another coating to go on top of it , chassis coat if i recall . I have used por 15 for years on quite a few cars in a lot of situations . I can't say enough good things about it .... yes it is hard to get off skin . When I was doing a lot more resto work I was called sir splotchy of por 15 by the guys in the shop
