por 15 - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-08-2003, 04:01 PM
Post por 15
Where can I get some of this stuff and how much is it??? Is it designed for metal surface only or can it be put on paint/primer surfaces?
Old 01-08-2003, 04:55 PM
Post
go to por15.com. It about a hundred bucks a gallon. They have all the information you need
Old 01-08-2003, 04:59 PM
ztoy's Avatar
speed freak
Post
POR 15 is excellent, but you really need to follow the manufacturers instructions to the 'T'.
Old 01-08-2003, 05:46 PM
Post
THANKS A LOT GUYS,,,,,I APPRECIATE IT.
Old 01-08-2003, 08:14 PM
Weimer's Avatar
Kenneth Howard hates you...
Last journal entry: door pics smaller
Post
I believe I read somewhere that Por15 itself is sensitive to sunlight...Don't they sell a paint that goes on as a topcoat?
I know Dad used it on his frame and it(Por15 only) turned out great.He used it on bare steel.
Later,
WEIMER
Old 01-08-2003, 08:20 PM
Halloweenking's Avatar
Fantastically cannibalistic!
Post
Yes Weimer, Por-15 is UV sensetive on its own, it will fade or change color in in direct sunlight. Por-15 recomends you use a topcoat on anything that will be in or could see direct sunlight. The have a variety of topcoats to choose from.
HK
