Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - POR 15 to fix Cancer on Steel???
Old 01-10-2006, 03:46 PM
Rick WI Rick WI is offline
That is not an appropriate application of POR at all. You need to have the door skin removed, bare frame cleaned of all corrosion, repaired if needed and a new skin applied. If new door skins are not available a clean used one or metal patching are the other options.
