Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - POR-15 or Powder coat
Old 08-12-2004, 08:04 AM
willys36@aol.com's Avatar
willys36@aol.com willys36@aol.com is offline
Wiki Edits: 21
I powder coat everything except body sheet metal - frames, suspension, fender wells, engine blocks & heads, clear powder coat all my polished aluminum like tranny cases, valve covers, etc. Impervious to virtually every chemical (including brake fluid, great for master cylinders) except paint stripper which takes it off easily. Infinite color selection including candies, no UV problems, penetrates inside tubulars due to the electrostatic charged powder. And is about as tough as you can get.
