por 15 question - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-26-2006, 07:42 PM
por 15 question
Painting a couple of bumpers and the door steps from a freinds jeep. Now i sandblasted them and im going to apply por 15 on them then i want to gravel gaurd them and put a topcoat on them. My question is do i need to put primer over the por15 then gravel gaurd and applpy primer again over the gravelgaurd then the topcoat? Or can i put gravel gaurd directly over the por15 then primer and add my topcoat? Thanks
Old 10-26-2006, 08:05 PM
I have used POR15 on several occasions and find it a great product to accept most paints/ primers. I would bet that the POR15 would be stronger than the gravel guard as long it is not exposed to UV light (sunlight), which you should then prime and topcoat. When using the POR15, follow the direction for the 3 steps needed (clean, etch, coat). Try a small area to see if the gravel guard "sticks" to the POR15 directly after it dries.
I starting using this about six years ago and I had to park my '62 in the back due to family health issues and pulled it out this past August and found no rust on the frame which I sealed with this product. Great stuff ...others tho will have different opinions.
Old 10-26-2006, 08:09 PM
Thanks kbawi. With the etching step do you need to rinse it off after applying it just like the marine cleaner you put on in the first step? doesent really tell me on the can if i need to rinse it off or not? Thanks
Old 10-26-2006, 08:14 PM
I have always rinsed it off ...I think I read that somewhere in the instruction years ago. I sometime get impatient and the product did stick to those areas that were not rinsed. Good luck!
Gary
Old 10-26-2006, 08:20 PM
Leave the Metal Ready on for 15 or 30 minutes and keep it "wet", then rinse it off. Had to look at the directions again ...wow, thought I didn't need them again.
Old 10-26-2006, 08:39 PM
Thanks again kbawi i will follow those directions.
Old 10-26-2006, 10:10 PM
cucumber1949's Avatar
T-Bucket, Corvette, Mustang
Apply Marine Clean, rinse, let dry thoroughly. Then apply the etch, rinse, let dry thoroughly before applying POR-15 rust preventive paint.
Old 10-27-2006, 07:50 AM
I am not a big fan of POR 15 however I did use it on the underside of one of my Mustangs a couple of years ago (good results) and in researching the stuff I found that if the parts are sandblasted then the etch is not only not necessary but not recommended! A sandblasted part offers the best possible surface and no other prep is needed.
Old 10-27-2006, 09:19 AM
Ya there seems to be a lot of different opinions i got locally here too about putting metal prep on a sandblasted surface. I cant see them using metal prep in a industrial application such as a bridge as por 15 claims it is used on applications such as that. Afterall time is money and going through all the steps in a major application such as that would be very time consumming. I'm going to follow the three steps anyway and see how it works out.
Old 10-27-2006, 10:06 AM
If you will go to POR's web site you will find in the Q@As that metal ready is not always required. As I understand it you should not use Metal Ready on a sandblasted surface for the same reason you would not acid etch a blasted surface prior to priming. With a sandblasted surface the metal is already prepped and offers an excellent surface for adhesion so why would you want to etch? It seems that acid can be trapped in the rough surface and cause harm later so it may be that not only is it unnecessary but could actually cause problems later.
http://www.marine-paint.com/por-15-metal-ready.htm
383 stroker 73monte Engine 13 05-11-2016 11:17 AM
Question about vehical weight and engine question Thuggishruggish3000 Engine 12 03-24-2011 05:22 AM
question about a previouse question elrod1030 Engine 6 03-10-2010 07:35 AM
Switching to 200R Tranny question Gundarak Transmission - Rearend 4 12-05-2003 08:00 PM
nitrous 69BiRd Engine 2 11-28-2003 10:33 PM
