POR-15 questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-10-2013, 09:43 PM
CHEVY 64's Avatar
POR-15 questions
Hello to all,i got my project that im working on i had completly gutted my interior on my 66 impala convertible and wanted to por-15 my whole floor boards and trunk area,so i could just put it right over the rust correct? some 1 told me to ruff up the floors before applying it? and another question should i por-15 my doors beind the door panels while im at it? not the inside but the inner outer part? thanks
Old 06-10-2013, 09:45 PM
CHEVY 64's Avatar
forgot to ask could i or should i por-15 my convertible rack??? or would it be better to paint or powder coat it??
Old 06-10-2013, 10:53 PM
bodyman
convertible rack I would powder coat it and on the por-15 can't get up here in canada but online you can get the msds info.
Old 06-11-2013, 06:41 AM
the msds isn't going to help him at all unless he starts consuming it.
Old 06-11-2013, 06:53 AM
Pats55's Avatar
Good point, don't drink it. Rough it up with 80 grit try to get it back to bare metal ,use a acid etch. and,put down two coats of the silver then put black if you choose over that.That is a textbook application And don't forget to wear gloves.
Old 06-11-2013, 07:33 AM
Faith - Respect - Trust
Or, eliminate the Por-15 and use a good quality Epoxy Primer....better corrosion resistance, easier to apply and less chance of adhesion issues down the road.
Ray
Old 06-11-2013, 08:07 AM
boatbob2
por 15
I sand blasted my 48 ford coupe chassis,i used all por products to coat the chassis,about 3 months later,the por came off in sheets,in my opinion,it is money wasted,cant beat SPI EPOXY...
Old 06-11-2013, 08:31 AM
Last journal entry: Body
I hear some of these stories about POR peeling off in sheets, I don't get it. I have used the stuff for years and never had a problem with adhesion. Of course I always follow the directions. Not saying the other people did not, maybe some of these were a bad batch?
Old 06-11-2013, 08:38 AM
496CHEVY3100's Avatar
Built Not Bought
Last journal entry: 53 ad3100
Go to POR 15 website ,I used it on my truck no problems ,*** is not as smooth as I would have liked ,I scuffed my frame with 36 grit Before I received paint and instructions ,There sight says Do Not sand or it will not stick prone to Peel ,on the sight it says you brush it or spray it ,I brushed mine if I could do it again I would spray it . I will try to post a picture.
ID:	74798   Click image for larger version
Old 06-11-2013, 08:44 AM
I've used Por-15 and had great results...took a set of new headers, sandblasted them, let them sit and oxidize for a few days and applied Por-15...12 years later, the headers are still black and look good. I also had a customer of mine apply Por-15 on the inside of a pair of fenders...it literally fell off. I agree with Sedanbob, if you follow the instructions, chances are it will work...that being said, if a product is that susceptible to not adhering (and there have been numerous threads on this very subject...and I have yet to see a thread about Epoxy primer not sticking)and a quality Epoxy Primer will stick like poop on a blanket...why chance using NOT using a quality Epoxy Primer?
Ray
Old 06-11-2013, 09:20 AM
Built Not Bought
Once opened it has a short shelf life ,don't try to save it for next job ,,I bought a gallon only needed a quart.so I gave remainder to a friend to use on his project,,it helps some to put a sheet of shrink wrap under lid before sealing it ,,much easier to get lid off next time you use it ,,which probably every one already knew that.
Old 06-11-2013, 09:59 AM
Exactly why I buy it in quarts amd use a "turkey baster" to get it out of the can so I do not get in the grooves on top of the can.
Old 06-11-2013, 10:17 AM
Built Not Bought
never thought about that,,i have ben using 2 in tape half way around can to make a pour spout ,dont spill on side of can to cover writing makes pouring easy ,when finished take off tape throw it away you are clean ,,
also a tip I drill a 1/8 hole in the lip of the can so it can drain back in can it will still seal good ,the plastic is just insurance and ease lid removal.
Old 06-11-2013, 11:07 AM
ogre's Avatar
the 'Duracell Project'
i used por15 on my frame 5 yrs ago, no problems, no fading
i put a 2 big screws in the lid and remove them to pour it out
saves the por15 for yrs
Old 06-11-2013, 11:43 AM
Pats55's Avatar
guess who wrote the application guide for that product in 1987. Someday I will try to explain the technology behind the coating That generic type of coating when manufactured correctly and used directly as one of the most powerful systems available Most bridges that use this type of system can go as long as 25 years without a repaint I don't feel like starting any type controversy. Besides, my mothers calling me
por-15 Mrwood Body - Exterior 10 11-24-2006 11:43 PM
POR-15 questions JLarson69 Body - Exterior 2 09-04-2005 12:44 PM
has anyone used Por-15 here? Bettyhavok Body - Exterior 1 04-27-2005 05:54 PM
H.K. Por 15 questions? slider in wa Body - Exterior 18 04-04-2005 08:18 PM
More Por 15 questions ? FiefSS Body - Exterior 2 09-25-2003 11:10 PM
