thats all it needs!just make sure its got no oil or grease on it
some people said it might peel if its just clean surface, it likes to be on rusty surfaces
Don't get confused here. A clean SANDBLASTED surface will be ok. A clean smooth or just raw metal surface will not.
POR 15 will stick to rust or clean SANDBLASTED surfaces. |
Thanks, After a lot(and I do mean A LOT)of hours chipping,scraping,bleeding and swearing, I finally removed the 40 year old undercoating from the underside of my new project(64 1/2 mustang). I then sandblasted every remaining trace of paint and visible rust from the surface. I know the next step is supposed to be to etch with acid and then wash with water but when I looked at that pristinely clean metal I just could not bring my self to spray water,let alone acid on it. This is the first time that I have used por-15 on a large area and the results are fantastic! I sure hope this works and I belive it will,time will tell.
As long as it is not smooth metal it will work.
Troy __________________ If you don't make mistakes. your not doing anything. 69 ss rs full custom camaro 98 ISCA grandchampion 69 ss rs bb camaro wifes driver 66 Elcamino 350/all dz parts,ac,windows,loaded,my driver 69 ss chevelle bb conv.fresh frame off 26 T sedan street rod |
Hi Troy,
I was in a jobber in WV a week ago and a guy came in with this stuff peeling allover. What he had done was use a 24 grit grinder and jobber told him it would only work over rust or sandblast with sand. He actually was reading from a tech sheet. I don't know if thats the case or not just pointing out to you. Barry |
POR-15
I sandblasted my frame and painted on POR-15 Semi Gloss with a paint brush. I used no other prep. just make sure there is no oil on it,and that you wear gloves and old clothes. It's a bear to get off!! Good Luck ROBO
If you want to use por 15 on smooth metal, you can by using there product called Metal Ready, it etches the metal.
They recommend it on any surface that you are going to coat with por 15. Even rust. Troy __________________ If you don't make mistakes. your not doing anything. 69 ss rs full custom camaro 98 ISCA grandchampion 69 ss rs bb camaro wifes driver 66 Elcamino 350/all dz parts,ac,windows,loaded,my driver 69 ss chevelle bb conv.fresh frame off 26 T sedan street rod |
