POR 15, your input - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-03-2010, 08:11 PM
POR 15, your input
I have tried a sample kit and I LOVE this stuff. I have also talked to a few people that have used it for 8+ years and its still working strong.
I have also read bad reviews on it, mainly from the guys on this site. I was just curious what you guys did or didnt like about it? What problems you had when using it? Were your problems strictly product based, poor prepping or topcoating options being compatible???
Any input is appriciated. I purchased this to use on my engine bay and suspension parts.
Old 11-03-2010, 08:17 PM
001mustang's Avatar
What I don't like is the price.
I'll just stick with the "cheap" epoxy.
I
Old 11-03-2010, 08:32 PM
1930u's Avatar
Last journal entry: 1930u more fuel line plumbing
I use rustoleum 777 satin black. $7.00 a quart at Lowes. Just let it dry a full 24 hours between coats, or it will check out. I love the stuff and I've been using it for years. You can cut it with acetone and even sand between coats. There are probably a hundred threads on the forum about this pro's and con's.
IMO- POR and KBS are hype. Use epoxy or rustoleum and save $$$$$
Old 11-03-2010, 08:45 PM
1930u's Avatar
My current project wears Rustoleum 777 Satin Black. Total cost for entire frame $8.00. I wish they made cologne.
ID:	49542   Click image for larger version
Old 11-03-2010, 08:59 PM
T-Bucket, Corvette, Mustang
If you haven't already viewed this:
Which primer over POR 15?
then it may help you with the pro and con opinions. You just have to slog through the egos, shouting, and posters who say they don't care a whit but keep posting anyway. LOL this is a fun forum
Old 11-03-2010, 09:00 PM
001mustang's Avatar
You just reminded me of my DryLock experience.
I bought into all the hype.
Worked good at first.
After a few years it started popping loose like a bad sun burn.
Old 11-03-2010, 09:54 PM
Jon's Avatar
Jon Jon is offline
Hotrodders.com Administrator
Wiki Edits: 7314
This wiki article may be helpful to you: Rust encapsulators.
Need input on building my first engine.. whitman66 Engine 6 07-26-2010 08:06 PM
4T60E ('93) - Input end play clearance question/prob [long] mjw Transmission - Rearend 2 03-24-2007 02:56 PM
Transfer case - NP 203 - 205 jrm123180 Transmission - Rearend 2 03-24-2006 07:36 AM
Input shaft conversion for C4 k2mooch Transmission - Rearend 8 12-29-2003 10:36 AM
Need input on titanium rods Blownolds Engine 3 12-07-2003 04:43 AM
