Por-15, ZeroRust, Rust Encapsulator, or Urethane? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-22-2004, 01:47 PM
I am having trouble making up my mind what to do on the undercarraige of my car. I am in the process of taking it to bare metal and repairing rusted areas by cutting/replacing with patch panels.
I was thinking about por-15 but after using it some on my daily driver, I am a bit disappointed with how the topcoat sticks to it. I understand that por-15 makes a tie coat primer that is made to bond to the por-15 but the last thing that I want to see is my topcoat peeling off after I put all this hard work into the car.
I read a bit of info on ZeroRust and it appears that topcoating is easier than por-15 and it is cheeper.
I also read up on Eastwood's rust encapsulator which uses a totally different technology than por15/ZR but also gets good reviews.
Lastly, I am removing all rusted sections and replacing with new steel. The car will not be driven in rain/snow. So I guess I could forget about it all and just go with a standard etching primer, primer, BC/CC. But I'd hate to see this car start to rust again as well.
So I'm torn. I just want a nice looking finish that won't rust. So what do you recommend?
No matter what, I would like to paint the undercarraige the body color. So I will be using an acrylic urethane BC/CC as my topcoat.
kev
Old 04-22-2004, 02:46 PM
willys36@aol.com's Avatar
Wiki Edits: 21
Powder coat it.
http://hotrodders.com/showthread.php...der+coat+frame
Old 04-22-2004, 02:48 PM
GMW GMW is offline
If you have access to shoot the bottom, like a rotiserrie, I'd just shoot it the same as the rest of the body.
Old 04-23-2004, 06:21 PM
IT'S MY JOB...
Check out BarryK's post at the top of the list on ZeroRust...Bryan
"Deserves it's own post" is the title
Old 04-23-2004, 08:36 PM
mitmaks's Avatar
Last journal entry: Grille
por15 works well but id have to agree with above post, id powdercoat it body color as you want
