porportioning valve - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-31-2002, 04:42 AM
Post porportioning valve
I have converted a 69 chev 1/2 ton with manual drum brakes to 72 power disk brakes. All parts are new except the porportioning valve. I do not have any pressure to the front disks. Do I need a new valve or an adjustable one?
Old 12-31-2002, 05:40 AM
Don Meyer's Avatar
Post
Did you use a new master cyl & brake hoses? I'd crack open the brake line entering the combination valve & see if you are getting fluid to it......Don
Old 12-31-2002, 02:28 PM
46_stvblt's Avatar
Post
I had to bleed the prop. valve a couple of times before I got the system to bleed out totaly. For some reason the whole system would not bleed out normally. It just locked up and I could not get fluid thru to all the bleeders. after much screwing around I bled the prop valve and then I started to get fluid.....GlennK
Old 12-31-2002, 03:26 PM
NAIRB's Avatar
Post
May not be your problem, but sometimes, the proportioning valve gets off center when you are bleeding, try kicking the pedal very hard once to center the valve.
Old 12-31-2002, 08:11 PM
ssaza's Avatar
Post
did you change the distribution block on the frame?from the 69 to the 72?I recall that the 69 had a proportioning valve by the master cylinder,then a block on or by the frame,where all the lines hook up to,Make sure you use the 72 distribution/proportioning valve,this is dual fuction.this could be your problem. Good Luck
Old 01-01-2003, 05:15 AM
Tazz
Cool
The porportioning valve is different for drum/drum and disc/drum. If you get a spongy padal change out the valve for the correct one.
Todd
