Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Porportioning valve and brake switch mounting
Old 02-15-2005, 08:31 AM
DDGETHS DDGETHS is offline
New Member
Does it matter where the Porportioning valve and the brake pressure switch are mounted. I have a firewall mount master cylinder. I was thinking about mounting the porportioning valve on the frame in the engine compartment. My other options are on the fender or on the firewall. Anyone have a suggestion? Also what is the best place to mount the brake pressure switch? Front brake line or back brake line, close to the master cylinder???
This is going on a 57 Willys Wagon 4x4.. Disc and drum setup..
Pete
