Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Porportioning valve and brake switch mounting
Old 02-15-2005, 11:01 AM
willys36@aol.com's Avatar
willys36@aol.com willys36@aol.com is offline
Wiki Edits: 21
The proportioning valve can go anywhere it is convenient near the master cylinder. I have seen them attached to the master cylinder with very short connecting tubes and clear down on the frame with long connectors. I always put the brake light switch in the rear brake line since it is a lot less cluttered and easier to access there. Can go anywhere in any line.
