Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Port CFM vs. Valve Size vs. Port Velocity...Data WANTED!
  #20 (permalink)
Old 04-13-2006, 11:45 AM
NAIRB's Avatar
NAIRB NAIRB is offline Moderator
Originally Posted by Elevinpointsixtoone
NAIRB...wasn't trying to bust your nuts was mostly a tounge in cheek response. Mabye I have not stated it clearly, going to some new heads makes the most sense and I'm starting to shop around. I have heard, and maybe you guys can comment, that the header manufacturers will not gurantee their product will fit an aftermarket head. I called Hooker when looking for my 2112's (57 chev, full length, 3/4", manual, 605 or stock steer box, no glide mounts, tuck inside frame rails, angle or straight) and they were like your not gonna use Brodix or Dart heads are you? At that point I said no and they were like "good, cuz those won't fit those heads".
Is this going to open another can of worms? Should I look at some GM fast burns or something else made by GM just to make it a no brainer on the exhaust side of things?
Are you absolutely bent on using aluminum?
