Port CFM vs. Valve Size vs. Port Velocity...Data WANTED! - Page 4 - Hot Rod Forum : Hotrodders Bulletin Board
  #46 (permalink)
Old 04-17-2006, 12:37 PM
11:1 Compression Will Not Make A Good Street Car
As Far As Head Flow......i Suggest Small Block 400 Heads Ported To The Max.then Fitted With Oversized Valves..around 480-550cfm......truthfully..if You Spend More Timde Getting The Heads Right You Will Have 550+ Hp... Next Is Cam,headers,
Intake\carb( By The Way Two 5oocfm Carbs May Be Pushing It ...you Will Definately Need So Strengthen Ur Bottom End With Arp Bolts....and Billet Connection Rods.
Exhaust Diameter Formula ChevelleSS_LS6 Engine 11 04-27-2012 09:21 PM
Fabricating intake manifold. gemini86 Engine 25 10-02-2009 01:10 PM
cfm size for 360 dodge 4doorjoe Engine 2 10-11-2005 07:55 PM
GM fast burn heads batman09 Engine 1 10-26-2004 09:32 AM
Cam Help black66 Engine 3 05-12-2003 06:15 PM
