port matching heads - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-23-2002, 02:35 AM
nosliw721's Avatar
chopster
Post port matching heads
I am in the process of swapping the motor out in my 86 2wd suburban. Taking out the 350 and installing a 454. I pulled the 454 down for inspection and am planning on port matching the heads and intake. I have done mopar big blocks and no problems, but I am wondering how much meat I can take out of the head ports without getting too thin? I am using the intake gasket as my template and I will open the ports to match the gasket opening then gradually blend into the stock runner while removing any casting slag as I go. I am using an edelbrock performer intake on this motor. Any other trick mods I can do on my own? any thoughts on my proposed port matching?
thanks,
mark
Old 12-23-2002, 05:40 AM
TurboS10's Avatar
Last wiki edit: Auto Terms and Definitions Used in Modern Engine T... Last photo:
Wiki Edits: 2
Post
Sounds like your procedure is sound. If you are just port matching the material should not be a problem. If it looks like you are going to be removing alot of material, I would find a smaller gasket(port size). Keep in mind that you only want to smooth flow. Making it larger will not help anything.
Chris
Old 12-23-2002, 04:46 PM
bullheimer's Avatar
NEVER use credit cards!
Post
yeah, if its just fairly stock
