We're winning the case!
Hotrodders Bulletin Board > Tech Help > Engine
  #1
Old 12-06-2003, 12:01 PM
Jmark's Avatar
Jmark Jmark is offline
port matching the intake.
Well, i'm finally ready to bold on my intake on my 350. Some time back I posted about port matching my 882 heads to my intake gaskets. Learned alot and had fun doing it. I have an Edelbrock Performer Qjet intake going on and put one intake gasket on the intake to see how it looked. What I noticed is the intake runners are a little smaller than the gasket and head ports. Is it necessary to match the intake to the gaskets and heads if they are a little smaller? I understand the need not to have smaller head ports against the manifold due to the flow impacting the head surfaces, but is it bad to have the intake a tad smaller than the heads since the flow is going from the smaller intake to the larger head runners?
Old 12-06-2003, 12:08 PM
NAIRB's Avatar
NAIRB NAIRB is offline
If the intake runner is slightly smaller, that is not a real problem, vice-versa is a problem.
Old 12-06-2003, 12:15 PM
Auto-Part's Avatar
Auto-Part Auto-Part is offline
If you Can Dream it, You can D
Nice clean looking engines. Porting in most cases is over-rated. A good polishing and cleaning of the runners should be a 1st choice. Also like the fact that you are using the Q-Jet carb.
lluciano77's Avatar
lluciano77 lluciano77 is offline
Short changed on common sense
A little overhang coming from the intake isn't bad. Like you said the other way around isn't good.
Old 12-06-2003, 12:21 PM
willys36@aol.com's Avatar
willys36@aol.com willys36@aol.com is offline
willys36@aol.com's barnstar
Wiki editor
Last wiki edit: Fiberglassing
Wiki Edits: 20
Actually, there will potentially be a slight performance drop with the discontinuity. Intake manifolds are designed using 'organ pipe' theory - taking advantage of sound pressure waves traveling up and down the runners to 'supercharge' the cylinder just as the intake valve closes at certain design speeds. If there is any change in diameter in the runner that the engineers didn't anticipate, there will be pressure and vacuum reflections that will affect performance. It isn't just a matter of pressure drop. For a cruiser or street engine I wouldn't give it a second thought. However, if you are planning on drawing an occasional time slip at the Friday night drags, I would go to the trouble of port matching.
Old 12-06-2003, 01:33 PM
Jmark's Avatar
Thanks for all the input. The left engine is going in my truck. Its a dialy driver/boat puller. Guess I'll go put it on and bag it up. the right engine is going in my sons 4X4 crawler.
Mark
Old 12-06-2003, 06:16 PM
badknuckles's Avatar
badknuckles badknuckles is offline
you talkin to me?
nairb hit the nail right on the head
Old 12-07-2003, 05:47 AM
troy-curt's Avatar
troy-curt troy-curt is offline
Shop Owner And Troll Hunter
Willy is right. if your already doing it, go all the way and match them all.
Porting is the main thing, and the most important. Polishing is a waste of time.
Troy
69 ss rs full custom camaro 98 ISCA grandchampion
69 ss rs bb camaro wifes driver
66 Elcamino 350/all dz parts,ac,windows,loaded,my driver
69 ss chevelle bb conv.fresh frame off
26 T sedan street rod
Old 12-07-2003, 07:08 PM
bullheimer's Avatar
bullheimer bullheimer is offline
"al Qaida live in a Nebula"
i put my rpm on my gasket matched heads without gasket matching the intake and i cant see any problems. i agree with everyone else as well.
Old 12-08-2003, 10:13 AM
Cameron Cameron is offline
267 heads on 305; port matching
305 heads and presumably 267 heads (haven't pulled the 267 heads off yet) have intake ports quite a bit smaller than 350 ports. Does anyone know if gasket matching these heads to match a 350 manifold (either a 79 350 truck manifold or an edelbrock performer) will break into the water jackets?
My 305 uses flat-tops and a pair of 416 heads (10:1 compression I believe, 212 psi cranking pressure) to push a 79 3/4 ton on propane. Since I do a lot of driving between 70 and 100 mph (I have a 9 hour once/month commute), I want all the power I can get. The cam is a crane energiser with a designed operating range of 1600-4600rpm selected to maximize economy.
When I get the 267 heads off, I will have hardened seats installed, intakes cut for 1.84 valves, pocket porting, and perhaps gasket matching. The 416 heads I am presently using do not allow proper intake line-up, so i want rid of them -I think the dowel holes are machined in the wrong spot.
Also, will a 30 degree back-cut on the valves help flow noticeably?
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
