Port shape for closed chamber 3856206 heads - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-28-2010, 09:16 PM
truckboy61's Avatar
I'm trying to replace the flange gasket on my 3856206 heads. They are oval ports according to the Internet off a 1965 396, the exhaust port looks square to me? Is this possible? If so could it be oval intake square exhaust ?
Old 03-28-2010, 10:00 PM
ericnova72's Avatar
More for Less Racer
All the BBC heads have square-ish shaped exhaust ports. When talking Oval or Rectangular(Square) port in reference to BBC heads they are talking about the intake port only as all the BBC exhaust ports have a square shape.
Only exception is the rare L-88/ZL-1 Aluminum heads with round exhaust ports.
Old 03-28-2010, 10:14 PM
truckboy61's Avatar
What gaskets should I use ? The Hedman web page offers both round and square and the square ones appear to match better then the round ones ? I took off the old gaskets and the indentation around the round gaskets is that square type of " big block" oval
Old 03-28-2010, 10:27 PM
ericnova72's Avatar
More for Less Racer
Whatever shape best matches the header flange you have.
Old 03-28-2010, 10:41 PM
truckboy61's Avatar
When I replace the intake gasket should the same advice apply or should I use oval ?
Old 03-28-2010, 10:43 PM
ericnova72's Avatar
More for Less Racer
Yes the same applies.
AFR or Vortec heads? Cam? rodent Engine 18 06-08-2010 03:50 PM
454 question? BigBlockT Engine 20 01-22-2009 03:08 PM
Any Experience with Large Port Vortec Heads? ezobens Engine 5 12-30-2006 09:28 AM
olds #5 head johann Engine 1 07-30-2006 10:05 PM
difference between closed & open chamber heads bigwildgrin Engine 2 05-13-2005 09:47 PM
