ported 305 heads on a stock L31 350? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-28-2012, 07:25 PM
i putting a 85' silverado 4x4 together "clean inside and out straight all the way around all org truck had a 305/ 700r4 3.08 gears, now iv got a stock L31 motor no heads, but iv got a desint set of ported to the gills 305 heads, how hogh will that run the compression up, i want to run 87 octane, im even thinking about useing the factory cam "roller' or a eddy's performer cam not sure yet, a weiand seath high rise, and a good holley or eddy carb...any ideas??
Old 09-28-2012, 09:47 PM
Valkyrie5.7's Avatar
www.generationhighoutput. com
Last wiki edit: Painting chrome wheels
Last journal entry: Stopping my journal entries here
Wiki Edits: 15
what casting heads? There's very few 305 castings worth a snot, ported to the gills is hyperbole, I assume. If not, just toss em.
Old 09-29-2012, 08:34 AM
the last three #450 1.84/1.50 valves, i had to use 1 3/4 headers just to get the exhaust ports to seal off, the intakes have been port matched to the 1205 felpro gaskets.
Old 09-29-2012, 05:52 PM
Wiki Edits: 15
Not the worst head casting but I would be hesitant running them because they sound like they've really been hogged out. I know f-bird 88 on here suggests opening them up significantly to make power for a 350 but this sounds excessive. Maybe he'll chime in. Any pics of them?
Old 09-30-2012, 09:53 AM
no pics right now, maybe right i could find some defferent heads to use....
Old 09-30-2012, 10:47 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The Vortec heads original to the L31 would be my choice for performance. But using low octane gas might not be an option unless the compression ratio was lower than you will get using FT pistons and a good quench. If the pistons are dished you might get away w/it if the cam is chosen carefully.
Old 09-30-2012, 11:54 AM
Wiki Edits: 15
Like Cobalt said, a good set of vortec castings would be my choice. Even in a truck a 64cc swirlport like 193 can be had for cheap and not have any issues with compression and quench. They'll run out of steam by 4500 rpms, but it's going in a truck right?
What Cam is best for stock L31 Vortec 350 heads? 327 Build Colder2012 Engine 7 06-13-2011 06:22 PM
Stock 350 with 305 truck heads? CrazyT Engine 3 08-04-2009 01:15 PM
chevy 305 stock,ported polished, Holset H1E turbo. 74chevyflat Engine 19 06-02-2008 04:03 PM
Singh's Grooves in Ported & Milled vortec heads on stock 350 automotive breath Engine 204 01-31-2007 07:38 PM
Ported & Milled vortec heads on stock 350 automotive breath Engine 23 11-18-2006 02:07 PM
