We're winning the case!
Hotrodders Bulletin Board > Tech Help > Engine
  #1
Old 11-15-2006, 04:57 PM
automotive breath's Avatar
automotive breath automotive breath is offline
Singh's Grooves in Ported & Milled vortec heads on stock 350
I am porting a set of 062 Vortec heads for an otherwise stock (including fuel injection) 97’ 350 in a 4 wheel drive pick-up. I will be milling the heads to assure the surface is true.
My question is can I mill the heads to raise the compression to further improve performance with out detonation? If so what’s a safe amount to mill?
Old 11-15-2006, 06:24 PM
BOBCRMAN@aol.com BOBCRMAN@aol.com is online now
Vortec heads are very thin GM castings and I will not mill them more than .010 which is approx 1.5 cc from the combustion chamber. I have seen them milled .020 or more. They tend to crack across the center deck.
Old 11-15-2006, 08:04 PM
Vortech 4.3's Avatar
Vortech 4.3 Vortech 4.3 is offline
jack of all trades
i will agree that they are thin. i wouldn't mill anything, unless it is needed.
it looks like you did a good job porting.
Old 11-15-2006, 08:18 PM
Thanks,
I measured the head deck thickness to be 0.275", this appears to be thick enough to allow milling.
I’m interested in raising the compression with in the detonation limits; I can’t find specifications on the engine’s stock compression ratio or camshaft specs to calculate dynamic compression ratio.
Old 11-15-2006, 08:35 PM
jack of all trades
my engine, stock, is 9.2-1. i would expect your to be the same.
cam, i can't say on the specs. but i do know they are pretty mild.
Old 11-15-2006, 08:40 PM
The engine is still running so I estimated some of the numbers to come up with this:
Cylinder Head Volume (cc) 64
Piston Head Volume (cc) 10
Gasket Thickness (in.) 0.026
Gasket Bore (in.) 4.166
Cylinder Bore Diameter (in.) 4.0
Deck Clearance (in.) 0.030
Stroke (in.) 3.48
STATIC COMPRESSION RATIO 9.3:1
You think I can bump it up to 10:1 with the stock camshaft?
With a 0.040" mill at 1.5 cc per 0.010"
Cylinder Head Volume (cc) 58
Stroke (in.) 3.48
STATIC COMPRESSION RATIO 9.96:1
Old 11-15-2006, 08:50 PM
jack of all trades
your asking the wrong guy about that. i have a vortech blower on mine, so i don't need any more static compression. do you plan to use 93 octane ?
Old 11-15-2006, 08:52 PM
I want to get the compression as high as I can and still use the 87 regular.
Old 11-15-2006, 08:56 PM
curtis73's Avatar
curtis73 curtis73 is offline
Hates liver, but loves Jmark
curtis73's barnstar
Wiki editor
Wiki Edits: 16
Then don't raise it. Its on the edge as it is using the stock knock sensors and EFI. I'd not raise it unless you plan on more octane. The polished chambers will help, but not much more than .1 or .2 additional.
Polished chambers might have added a cc or two and a clean up milling will probably take you back to stock CR. Sounds good to me.
Old 11-15-2006, 09:01 PM
Slimpikins Slimpikins is offline
If I were you I'd cc each chamber to make sure its 64cc. I had my vortecs decked .010 and they measured 65.5cc. also I'd cc the pistons as well. I wouldnt mill the heads any more than I absolutly had to. The 062 casting is better than the 906 casting but they still crack easily. I would have the block zero decked or at least decked enough to make up the difference in compression.
I used a set of KB 120 KiethBlack pistons 7cc 2vr
the heads measured 65.5cc
deck ht is .015
4.30 bore
headgasket thickness .015 with a 4.100 bore felpro embossed shim
this gave me a static compression of 10.22
Old 11-15-2006, 09:08 PM
I haven’t CCed the heads but I will do so before and after milling. The short block is not coming out. During the holidays it just a head swap. I can adjust piston to head clearance with gasket thickness.
Yours does OK at 10.2:1? What camshaft and fuel?
Old 11-15-2006, 09:24 PM
Your thinking maybe 9.4:1 maybe 9.5:1 max. I supose I could put it on a scan gauge and check for knock retard before I cut anything.
Old 11-16-2006, 02:12 AM
curtis73's Avatar
curtis73's barnstar
Wiki editor
Wiki Edits: 16
My 906 Vortecs (uncut) are advertised at 64, but actually measured out to 62.5 or so. Tolerances from what I understand range from 61 to 66. Measure twice, cut once
Old 11-16-2006, 08:29 AM
DaSouthWon's Avatar
DaSouthWon DaSouthWon is offline
I put up the tools against$300
Check your squish area before you cut anything. You may end up increasing your detonation prob.
Old 11-16-2006, 09:10 AM
ap72 ap72 is offline
How fast is fast enough?
If I were you I would step the compression up to about 9.5:1 and run high ratio rockers and consider a more agressive cam. It looks like you did a fairly good job of porting, but its all in vain without lift numbers to match.
Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "Ported & Milled vortec heads on stock 350"
Stock 350 with 305 truck heads? CrazyT Engine 3 08-04-2009 01:15 PM
vortec vs phase 2 heads 71vegagt Engine 3 01-29-2006 05:12 AM
CC chamber of stock vortec heads!!! Johnny 5 Engine 1 03-10-2005 12:45 AM
NEW GMPP VORTEC heads !! terror385 Engine 1 07-11-2004 09:48 AM
1997 350 Vortec Questions bobfray Engine 6 11-28-2003 01:15 PM
