Ported Vaccum or Intake - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-09-2006, 01:16 PM
Iam currently working on a 72' corvette with the original 350 with an edelbrock 600cfm carb and in take on it. I was swaping distributors for an accel HEI unit with vacuum advance but on the carb i could not find any ported vacuum to hook the advance up to, i have talked to some other people about this and they said that GM runs on intake vacuum for the advance but regardless of where i run the vacuum hose to the car just doesn't run right. If i take the hose off it runs good but has no vacuum advance. Timing is spot on. Any ideas?? Thanks
Old 10-09-2006, 03:53 PM
vac advance
go to this site;www.camaros.net/forums/showthread.php?t=17599 and your answer will in there, towards the end in a section called "vacuum advance 101". I asked the same question about a week ago. If you can't get it , the answer is manifold vac....
Old 10-09-2006, 04:37 PM
Wiki Edits: 31
don't buy an Accel anything, unless you want to replace it later on when it fails
Old 10-09-2006, 04:43 PM
poncho62's Avatar
Wiki Edits: 5
Stock Chevys use ported vacuum for the advance. Its at the front of the carb about 1/3 of the way up.
Ported or manifold advance is an ongoing debate amongst hotrodders.
BTW, this being a vacuum question, I am moving it to the engine forum.
QUICK! I have ONE HOUR! Will this Intake work??? Dizturbed One Engine 3 05-14-2005 09:10 PM
Question about intake manifold distrobution for Nitrous experts... sizemoremk Engine 5 04-29-2005 11:16 PM
Theory: Intake volume vs cylinder volume / engine vacuum 59vette Engine 6 04-29-2004 12:03 PM
"Dry" Intake Manifold Question bluesman123 Engine 4 02-11-2004 12:12 PM
Cam Help black66 Engine 3 05-12-2003 06:15 PM
