ported vacumm - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-27-2008, 05:57 PM
ported vacumm
is there a way to modifya double pumper throttle body to provide ported vacum as i bought a proform main body and it does not allow for ported vac source unless you buy there throttle plate
Old 11-27-2008, 06:01 PM
Question is, why do you want ported vacuum?
Nearly every engine in every situation likes manifold vacuum.
Old 11-27-2008, 09:34 PM
because i want ported vacum
Old 11-28-2008, 12:49 PM
Mine doesn't.
351W stroked to 393 - Mighty Demon, MSD billet, Lunati voodoo cam - won't idle below 1700 rpm with manifold vacuum.
Old 11-28-2008, 01:34 PM
Originally Posted by rsk289
Mine doesn't.
I thought that I wrote "nearly every".
Sounds like a case of a carb problem being blamed on the ignition.
If hooking up the manifold vacuum causes your engine to rev up and you can't get it to idle down to the rpm it does on ported vacuum,
Bring your car into my shop and I will fix it for you.
Old 11-28-2008, 06:26 PM
Scot, I'd love to - but I'm in Cambridge, England. Bit of a trek.
It's the same with the Edelbrock, a Demon vac.sec and the Mighty Demon. No leaks, no detectable problems - dyno guys reckon it's how this motor is, and tell me to stick with the ported.
Old 11-28-2008, 08:49 PM
so can i modifie the base plate to get proted vac or not this was the question does not matter why i want proted vacumm just want to know if i can do this thanks and if you dont want to reply then dont
Ported Vacuum or Manifold Vacuum? Regal Beagle Engine 13 09-05-2008 01:30 PM
Vacumm pressure for booster Mel Smith Suspension - Brakes - Steering 10 05-10-2007 04:41 AM
ported vacuum vs. manifold vacuum ko.17 Engine 4 06-13-2006 02:53 PM
vacumm lines??? 11toe Engine 2 05-16-2006 10:06 PM
Ported Vacuum Reading at Idle? JohnTN Engine 29 11-09-2005 05:41 PM
