Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Porter Cable Compressor Help
Old 03-07-2005, 04:51 PM
oldred oldred is offline
In that price range I would suggest looking at Ingersoll Rand,Eaton or(my favorite)Quincey. The Porter Cable may be ok but for about the same money you can go with the best. You are are on the right track with the two stage as that means a lot but if you do look at some other makes compare CFM ratings and not HP or tank size as CFM means everything and power ratings and tank size mean almost nothing. Don't be swayed by the physical size of the outfit as CFM is what counts.
