Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Porting 396 chev oval port heads to rectangular port
Old 06-02-2012, 11:00 PM
martin7844 martin7844 is offline
Hello. Fellow Hot Rodders. I have a 1969 Chev BBC with original Oval Port heads. Can I port-grind out enlarge the oval ports to match a rectangular port tunnel ram Intake, with two 650cfm carbs. I also want to install a Comp Cam 11-213-3 Magnum Hydraulic flat tappet camshaft with .550 " int./ .550 exh. lift, & 292 duration. Will this set up dramatically increase my HP & torgue. THX, Marty.
