Porting 396 chev oval port heads to rectangular port
Hello. Fellow Hot Rodders. I have a 1969 Chev BBC with original Oval Port heads. Can I port-grind out enlarge the oval ports to match a rectangular port tunnel ram Intake, with two 650cfm carbs. I also want to install a Comp Cam 11-213-3 Magnum Hydraulic flat tappet camshaft with .550 " int./ .550 exh. lift, & 292 duration. Will this set up dramatically increase my HP & torgue. THX, Marty.
Hello Fellow hot Rodders. Thanks for your valuable Information. If there is not enough spare metal in the oval port head to "Port out", and If the super stock drag Racers in the 70's ran rect port intakes to their Oval port Heads. Well NO WORRIES!!! I'll but the rect port tunnel ram Intake for my 69 BBC oval port heads. THX again for your help. I'll keep you posted as to how this engine RUNS.Cheers, Marty.
I beg to differ, I have done a set of Squirvel ports on my dads 496....although you are right not much material on the roof BUT enough to make the top of the port Square and the bottom I left Oval...and it works really to good, as he already damaged the TH400 whitch had all new clutches re-built, and has recently switch to a bulletproof TH350 with a brake...it will be running soon and i will take pics/vid of the car so all might see what the "sqirvel ports" can do with port work
Much better cam for your tunnel ramed big block would be the comp 294s solid lifter version magnum cam.
The solid cams work a lot better than hyds in this rpm level, in BBC's the valvetrain is much heaveier than a SBC. If you want max performance from your BBC use a street strip solid lifter cam over a hyd. The 294s cam or something in that ball park is just right. EG Lunati street strip mechanical UD harold design cam #402A4LUN or #402A9LUN Be sure to use the right valvesprings, reguardless These cams are street strip friendly powerfull cams just right for your street tunnel ram BBC. The 292H cam is good but these Lunati/UDHarold solids will outperform it. These cams are easy to maintain. www.lunaticams.com |
| rectangle port intake with oval port head | brendawhit | Engine | 2 | 05-06-2009 11:26 AM |
| Will an oval port intake work with round ( peanut ) port heads? | quintorca | Engine | 6 | 02-14-2008 11:43 AM |
| Porting BBC oval port heads HELP | Bad Rat | Engine | 7 | 03-15-2007 07:42 PM |
| BBC oval port v. rectangle port | dinger | Engine | 6 | 04-25-2006 08:16 PM |
| BBC rectangular port intake, oval port heads.. | wildman926 | Engine | 14 | 10-14-2004 11:49 PM |
