Porting - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-08-2003, 02:04 PM
New Member
Post Porting
Is it possible to port cylinder heads without removing them from the block.
Old 01-08-2003, 02:13 PM
Post
you really dont want to try that, whats happing to the ground away metal?
Old 01-08-2003, 02:33 PM
72 chevy's Avatar
Post
It becomes <img src="graemlins/evil.gif" border="0" alt="[evil]" />
Old 01-08-2003, 02:40 PM
72 chevy's Avatar
Post
Hey, it aint much more work to just pull the heads and go from there...besides, if ya have trouble, just ask!!
Old 01-09-2003, 06:28 AM
SAE Member, ASE Master Cert.
Post
No, it is NOT possible to port the heads while they are on the engine. WHY would you want to do that, anyway?? Actually, anything more than slight porting in the valve pockets and matching the ports to intake and exhaust manifolds is pretty much a waste of time, unless you have access to a flow bench.
Old 01-09-2003, 12:12 PM
bullheimer's Avatar
NEVER use credit cards!
Post
sure, you just need this milwaukee drill called a "hole hawg" and a 1 inch Arbor Bit that electricians use. Use one that is about 12 inches long, insert into top of manifold, squeeze the trigger and waller out all the runners till you can stick a tennis ball through them!
oh yeah, to get rid of the excess metal filings, just remove one sparks plug at a time, while it's running and the filing will just be pushed out the spark plug hole. <img src="graemlins/crash.gif" border="0" alt="[crash]" />
[ January 09, 2003: Message edited by: bullheimer ]</p>
Old 01-09-2003, 01:05 PM
Post
bullheimer...better watch out, there are people out there who will actually try that
Then again, I guess they shouldn't be allowed to drive anyway . . .
Old 01-09-2003, 04:53 PM
Post
THERE WILL BE NO WAY TO DO SO EVEN TO GASKET MATCH WOULD EAT THE VALVE GUIDES IM SURE !
