Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - porting, gasket match question
Old 07-19-2013, 02:48 PM
thinwhiteduke's Avatar
thinwhiteduke thinwhiteduke is offline
Living In The Past
How does the gasket look on the head? If your going to 'port match' that's a different procedure. You need to blueprint the two surfaces together without the gasket and ensure that the head port is not smaller than the manifold port around the circumference of the port, the other way round , ' not so bad' Then make sure the gasket don't hang over anywhere. Depends how fancy your getting with the build.
Duke
