It certainly cant hurt to port match it to your heads. I dont remember from other threads what you have, but my Dart 230's were alot larger than my ports on my Victor Jr. intake. Plus being the EFI version I had big injector bosses sticking down. I decide it would be worth the few hours to port match and grind down the injector bosses. Like I say it cant hurt.
I found that a 1/2 inch drill and a HSS cutter worked very well on the aluminum. The slower speed seems to keep the cutter cleaner than trying to use a die grinder. Chris |
I took advice from an earlier thread on grinding aluminum and ordered a die grinder bit from Goodson. Man that thing chews fast and never clogs up either.
Just wondering, in addition to port matching the intake gasket area, is any work on the plenum going to help? |
I would leave it be, but that is just me.
Port matching the intake side of the manifold will definitely help upper rpm hp. If the intake is bigger than the head intake port, it will cause puddling though. If the intake is smaller than the head intake port, it will increase velocity of the a/f mixture. As far as the plenum, I'd leave it alone. If you get it too smooth, it will hurt atomization of the a/f mixture.
If it is a divided plenum, you can remove some of the top center and it will improve the upper rpm range. If it is an open plenum leave it alone.
Troy |
It's best to buy the manifold that best matches the size of your runners. That way the whole manifold will be sized properly. Then as recommended above, do the port matching routine. And high speed grinders work great w/ carbide bits on aluminum if you use grinder's grease that totally prevents sticky aluminum clogging of the teeth Eastwood sells it. I have a tube that has polished three tranny cases, several intake manifolds, etc., etc., and still has many projects left. Probably a lifetime supply for a hobbyist.
I have an add on question. I plan on working a Dodge 383 with MPI for the future, I'm planning on welding bungs onto a Edlebrock single plane manifold and matching it to a set of Edlebrock heads. I want to see if I can port the heads myself and I will match the heads and intake to the gasket. Question is, would I get any performance out of porting and polishing the single plane? I would think that it would. Most of the plenum will just be air, so I wont need the vaporization effect in that area. Oh almost forgot, I am looking at turbocharging it also. I feel that the smooth surface should help in the plenum, especially for the fact that it will be a positive charge. Any comments?
two things
you can gasket match the heads and intake. or you can have them flowed together. but grinding away at them defeats edelbrock's expertise.
![]() Chris |
On this subject, does anyone know if someone is still offering the 'extrusion' process where they force a paste loaded with carbide grit through a manifold, thus opening up the passages? It was hyped in the rod magazines for a time in the 90s and I have heard zero about it since. |
polishing intakes
I highly advise against polishing intake runners both in the intake and the head. The problem with polishing them is that it allows the fuel air mixture to become unsuspended, costing a lot of HP. What you want is a florentine finish. Something to do with laminar air flow, and since Im not an aeronautical engineer, I wont try to explain it. What I do understand is that you need a certain amount of roughness in the surface of the runners and ports to keep the fuel air mixture suspended.
Polishing on the exhaust port side, however, is an excellent idea. besides not needing the rough surface to keep the fuel air mix together, polishing the exhaust side reduces the ability of carbon etc to cling to the runners causing restriction. I heard a lot of hype about extrusion several years ago, but the cost was so prohibitive, compared to any benefits. I think it kind of died on the vine. You dont want to just go in and start cutting down the divider in a dual plane, indiscriminately. There is an outfit in Wisconsin called Brezinski that specializes in doing this with factory steel intakes for stock car racing, where stock intake manifolds are required. They also do a lot of other internal work in the intakes. Ive talked to them a few times. It takes a lot of time and work to get that just right. Take too much and you mess up a manifold, take too little and youve done nothing. Plenum chambers are a very finnicky area to play around in. |
Right, it's not for the novice. I've see a lot of butchered intakes at swap meets. The norm for the street on a duel plane is one inch deep and two inches long in the center of the divider. other than that it would take a lot of flow testing.
Troy |
