pos grnd to neg grnd - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-14-2009, 07:42 PM
While looking for some info pertaining to a problem I have, I saw a post from Irelandschild stating that a pos grnd starter will run backwards if connected in a negative grnd fashion. Is this true?
Old 09-14-2009, 08:31 PM
Wiki Edits: 31
yea, it runs the current backwards
Old 09-14-2009, 08:36 PM
BOBCRMAN@aol.com's Avatar
NOT TRUE!! I have run many old cars/tractors on positive ground converted to negative ground. The only thing that has to be done is re-polarize the generator/voltage reg.
Old 09-14-2009, 09:49 PM
Wiki Edits: 27
6 V starters
Up here in the cold rocky mountains we used to put 6 volt pos ground starters in our 12 volt fords so they would turn over at 40 below. just don't crank too long or you can fry it.
Old 09-15-2009, 12:14 AM
Joe G's Avatar
That's only true of permanent magnet electric motors. Old style starters had field windings, and since you would be reversing the polarity to both the field AND the armature, the motor will spin the same direction it always did.
Old 09-15-2009, 06:08 AM
Thanks for clearing that up. I was starting to think thats why it wouldn"t start. Joe
pos. ground hottrodz Electrical 2 01-13-2009 04:05 PM
pos. ground to neg. radio rick laplante Electrical 7 05-01-2007 07:12 PM
sparks from Neg side of battery... rbomar Electrical 10 02-27-2007 08:29 PM
6 volt pos. to neg. ground rick laplante Electrical 9 10-16-2006 02:50 PM
39 Ford - Neg or Pos ground? Tiger Electrical 16 11-14-2002 04:56 AM
