posi ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-04-2007, 01:17 PM
posi ?
I have just put a posi in my 55. The unit is for a 55-64 old drop out. Long story made short. I got this off E-bay installed and gear noise had it rebuilt. I put richmond gears and lube in it. Lube is gl-6 75w-140. When I make a Sharp turn it feels rough and jerky. Going straight it is fine. My question is this normal? Should I use Gl-5 75-90. I did not add any posi additive because it should have had it in the lube, should I?
Thanks
Old 07-04-2007, 01:21 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Thanks
It may be IF the oil had the proper additives for posi... mayb the oil has not fully lubed up the clutch pack yet??
I would add posi additive or use Mobil 1 gear oil. I've had real good luck with Mobil 1 myself...
Old 07-04-2007, 01:43 PM
Needs an additive. Even though some GM posi units dont require it. I had an Eaton and the shop put in a modifier for posi units. Yes needs additive or modifier
Old 07-04-2007, 02:37 PM
Always add some of the GM Posi-additive when filling a posi-unit. It's an additive because the regular lubes do not have it. It is made especially for posi-units. It used to be made out of whale oil - a long time ago, but now is made of other materials
Old 07-04-2007, 02:55 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
The lube you put in already has additives in it for limited slips.
Old 07-04-2007, 03:05 PM
Use the Gl-5 75-90w AND the GM posi additive. If it's making the noise and acting like you described it needs the additive. Do not use any of the synthetic lubes.
Old 07-04-2007, 03:46 PM
Even if the gear oil has the additives, it's never enough. Add the good stuff from GM.
Old 07-04-2007, 03:50 PM
wildman1932's Avatar
Dave's hot Rod Shop
Put posi additive in it.
Old 07-04-2007, 07:06 PM
justold's Avatar
posi rear
after my corvetts sit all winter i have the same problem , I go to a parking lot and make 10 right hand circles and 10 left hand circles and that fixes the problem. and you still need the additive
Old 07-04-2007, 09:16 PM
ok ok
Thanks I think I will try additive.
I blew my Auburn posi apart this week end. ElCa/monty Transmission - Rearend 3 07-02-2007 10:08 PM
ahhh what do I do? mixed up beraing cups, budget 8.5" posi install Warrant Transmission - Rearend 7 03-23-2007 09:39 PM
to posi or not to posi Gmachine Transmission - Rearend 17 03-23-2004 04:00 PM
7.5 Limited Slip POSI Aaron930 Transmission - Rearend 0 02-05-2004 10:18 AM
Posi? novatech Transmission - Rearend 3 01-09-2004 07:05 AM
