Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Posi
Thread: Posi
Old 01-08-2013, 11:15 AM
big gear head's Avatar
big gear head big gear head is offline
High Performance Rear Ends
What do you want to do with the truck? Will it be a street machine, drag race, off road? There are many differentials for that rear end, and getting the best one for the job depends on what you want to do with it. If you use 3.73 gears then you will need a 4 series. The 12 bolt has 30 spline axles stock, but you can upgrade to after market 33 spline axles with the right combination of parts.
