-   -   Which Posi? (http://www.hotrodders.com/forum/posi-225117.html)
1badchevy 10-17-2012 07:28 PM
Which Posi?
Does anybody know if a posi rear out a cop caprice will fit my delta 88? I think it should cause they both b bodies, but just checking.
E.Furgal 10-17-2012 07:49 PM
first what years..
SSedan64 10-17-2012 08:17 PM
X2^^ what Yrs.?
If the Carrier Bearing sizes and Axles splines are the same it will fit.
28 & newer 30-spline were available.
big gear head 10-18-2012 06:22 AM
Which rear end is in each of these cars? The B bodies used several different rear ends over the years, from the 7.5 10 bolt to the 12 bolt.
1badchevy 10-18-2012 11:40 AM
its a 84 and i believe it has a 7.5 but could possibly be a 8.5, i have to check, but i do know it is a 2.73
