Posi - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-02-2003, 05:09 PM
Meka's Avatar
Posi
Is there an easy way to make both my tires spin the same speed and same time on my oldsmobile like a posi trac rear end?
thanks
Old 12-02-2003, 07:15 PM
Meka's Avatar
Come on dosnt any one know how. I heard about welding the gears together would that work?
Old 12-02-2003, 07:40 PM
302 Z28's Avatar
Welding the spider gears together certainly would accomplish what you want, and it was common during the 50's. It will however make street driving a royal pain as every time you turn a corner one wheel will try to slow down and start skipping and hopping. If you are lucky you will not break an axle.
Vince
Old 12-02-2003, 07:41 PM
BOBCRMAN@aol.com's Avatar
If you want endanger yourself and more importantly other people, get involved in a lengthy and costly law suit, lose your vehicle and gain a few points on your liscence. Run your car on the street with welded spider (rear end) gears. I've been there, IT ISN"T WORTH IT!!
Old 12-02-2003, 07:50 PM
Meka's Avatar
Thanks for the help it dosnt seem like its to good on the car so im not going to try it lol.
Old 12-03-2003, 12:42 AM
billman's Avatar
The only way to make it like a posi is to change the carrier to a posi carrier. I don't know what year, etc. you have so that's all I can suggest.
