posi choice - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-19-2005, 03:37 PM
posi choice
I have a 78 malibu, and I want to put a rearend from a 86 - 88 Monte Carlo SS rearend. Will this work all G bodys swap out or do they. I want to know where I could find a SS rearend. I want to swap the entire assembly from drum to drum. Thanks
Old 06-19-2005, 04:28 PM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
rear end swap
Check out www.maliburacing.com
You should be able to find out there.
Old 06-19-2005, 07:13 PM
SinistrV6's Avatar
valve monkey
If you're trying to improve the strength, the MCSS rear isn't a very good choice. 83-84 Monte SS's (with NON od trans/3.42 gears) came with a 7.5" rear and 85-88 SS's (with od trans/3.73 gear) came with 7.625" rears.
You'd be better off looking for an 8.5" rear. They came in Buick Grand Nationals and T-Type sand Olds 442's from 1984 -1987 and some (but not all) '84 Hurst Olds.
Try www.gbodyparts.com and www.musclecarsalvage.net
There's Grand National rear end on eBay right now with a fair starting price (if it's a posi) GN rear on eBay click here .
They're occasionally for sale on www.turbobuick.com www.turbobuicks.com and www.t6p.com
Of course, if you're getting the MCSS rear for free or don't need the added strength, disregard all of the above!
Old 08-16-2005, 05:44 PM
Go for the GN rear much stronger than the MC!
I'm looking for one after I swap a LT1 in my SS!
Which Rear is safer, Posi or Not??? stereodud Transmission - Rearend 27 12-29-2006 06:06 AM
to posi or not to posi Gmachine Transmission - Rearend 17 03-23-2004 04:00 PM
7.5 Limited Slip POSI Aaron930 Transmission - Rearend 0 02-05-2004 10:18 AM
Where can i get a posi Dreadlord Transmission - Rearend 9 01-20-2004 09:15 AM
Posi? novatech Transmission - Rearend 3 01-09-2004 07:05 AM
