posi from a limited slip? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-28-2004, 12:05 AM
is there a way to convert a limited slip to a posi?
Old 02-28-2004, 02:30 AM
limited to posi
They are the same thing just different names . Fords equivalent name is traction lock . Open rear means 1 wheel gets traction ; the others mean both wheels get traction , and turn at about same time. If you jack car up ; turn tire , the other one will turn in the same direction ( usually) . Open single track ; turn tire and other will go in the opposite direction. You can make your single track rear into posi. but you will have to get a posi carrier to add and then have a person with experience to( set up gears ) and add to the posi.
