Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Posi or no Posi
Thread: Posi or no Posi
Old 11-21-2010, 07:29 PM
mud.man.rj's Avatar
mud.man.rj mud.man.rj is online now
posi or no
Maybe under a small load(gravel) it works but on a heavy load the clutch material slips abit as in worn out clutch pack. Probable, you will just have to pull the cover and check. Maybe look to see if it has a posi and if it does try new 80/90 and add some posi lube also and it will pickup, the posilube does wear out. Worth a shot.
