Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Posi or no Posi
Thread: Posi or no Posi
Old 11-21-2010, 09:30 PM
big gear head's Avatar
big gear head big gear head is offline
High Performance Rear Ends
The limited slip oil additive makes the clutches slip easier, so adding it will only make it worse.
If it has a "posi" and the clutches are worn out then it's going to spin the tires in opposite directions if you jack it up and turn one wheel.
The only way you are going to know what you have is to look inside. There is no other way.
