Originally Posted by mud.man.rj
Duh, limited slip additive does not make the clutchs slip easier not at all, it helps the clutch pack to lock up better, that is what it is for and it's only purpose.
Wrong answer. You've been misinformed. The additive is there to make it slip easier when cornering, to eliminate it from popping, clunking, snapping and jerking. It does not make it hold tighter.
