Posi or not - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-26-2013, 04:02 PM
deckofficer's Avatar
Last wiki edit: List of hotrodding forums
Last journal entry: Trans swap
Wiki Edits: 12
Posi or not
Looking for folks that are running 500+ HP in cars less than 1800 lbs.
Folks, I'm looking to be schooled. I have run posi before but on a car as light as ours (mine is 1790 lb), I have found that for any given tread patch area, our light cars will generally accelerate with minimum tire spin. Now that I have my little Track-T in the rarefied air you guys have been accustomed to (3.4 lb per HP), my first 40 miles of driving have me seeking advice from those that have been there, done that.
I was driving north on twisty hwy 49 about 2 miles from my house when I had an opportunity to roll some throttle on in 2nd gear. I was behind 3 cars as we entered (2) S curves with posted speed limits of 15 mph. After the second curve the road gets very steep and straightens out for about 200' but has a crest that blocks my view of any oncoming traffic, so I never pass there. After the crest it again gets steep but now I can see the road ahead for about 400' and have passed on this stretch before. This time with the new 427, the rate of acceleration was most satisfying, much more than the 355 or 383, even though one of the rear tires was spinning.
My question, is the increased rate of acceleration worth it? Is it much of an increase? I would prefer the safety aspect of no posi because when traction is lost on one tire the car still tracks straight. On my heavy hot rods I had no choice but to go with posi, and when both rear tires broke loose on a crowned road, then I had my hands full keeping it on the road.
Old 02-26-2013, 04:19 PM
BOBCRMAN@aol.com's Avatar
"and when both rear tires broke loose on a crowned road, then I had my hands full keeping it on the road."
Been there! Tries to take the low side, turns your knuckles white and underwear brown..But without the posi my Sportsmans get all smoky and sticky on one side..
Old 02-26-2013, 04:35 PM
life is a temporary assignment
Not to sure where your aways gone in such a hurry that you have to pass everyone up... beating everyone to the top of the hill will sooner are later catch up with you,, It's like riding a motor cycle,, They will get you sooner or later,, Becareful,, But I would never have 500+ hp in a car without a Posi... My roadster was as light as your's, Not 500 hp,, But it had a lot per pound,,
And I had no posi in it when I first built it,,Didn't take me long to add it,,, I like when I stick my foot in it, It stay's straite..
Old 02-26-2013, 04:59 PM
Wiki Edits: 12
My Corvette and blown 427 '55 Ford both had posi and on a crowned highway didn't stay straight when both tires lost traction. The fact that my rate of acceleration was much improved over the 355 and 383 with one tire spinning vs no tires spinning on the same place on the highway tells me that maybe I'm not losing much acceleration on a car as light as mine with the loss of traction on one tire. On the heavy cars I noticed a big drop in acceleration when both tires lost traction and then it would get squirrely, but today the rate of acceleration seemed constant with one tire spinning.
Still looking for others with < 1800 lbs cars to comment, as it stands I think for safety I'll not switch to posi.
do i already have a posi?? chevykid90 Transmission - Rearend 4 09-14-2010 04:22 PM
posi ? tomthecomic Transmission - Rearend 9 07-04-2007 08:16 PM
M-21 with a 3:55 posi daleb Transmission - Rearend 9 02-10-2006 03:56 AM
Non Posi to Posi-differential JeepStang94 Transmission - Rearend 7 02-28-2005 10:23 PM
Where can i get a posi Dreadlord Transmission - Rearend 9 01-20-2004 08:15 AM
