Posi traction for My Nova ... questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-27-2010, 10:56 AM
AMERICAN MUSCLER
How can i get poly-traction on my 72 chevy nova
Old 02-27-2010, 11:01 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Perhaps you are talking about a posi traction carrier in the differential?
Old 02-27-2010, 11:11 AM
AMERICAN MUSCLER
response
yea dats wat i mean
Old 02-27-2010, 11:36 AM
AMERICAN MUSCLER
Bossmane
how do i findout the size of my rearend?
Old 02-27-2010, 11:43 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
how do i find out the size of my rearend?
there is a joke in there.
what amount of bolts are on the cover of the center section of this differential?
Old 02-27-2010, 11:59 AM
big gear head's Avatar
High Performance Rear Ends
A '72 Nova should have the 8.5 10 bolt rear end with 28 spline axles. I recommend a new Eaton Posi. In my opinion the Eaton is better than the others and worth the little extra mony that it cost. Installation instructions are here. http://www.nastyz28.com/forum/showth...ht=change+posi
You will need to know what the gear ratio is before you order anything. If you have a 2.73 to 5.13 gear then the 3 series Eaton Posi wll work fine. If you have a 2.56 or 2.41 then you can not use the Eaton. You will need to find a 2 series Traction lock differential. They can be found in many '70s Trans Ams and at many swap meets. If you go with the new Eaton you will need bearings and shims to install it.
Old 03-28-2010, 09:52 AM
AMERICAN MUSCLER
Rearend Swap
Can i get the posi rearend off of another vehicle and if so which cars will fit my 4 dr 72 nova?
Old 03-28-2010, 02:40 PM
You can take the differential from any 8.5 10 bolt with 28 spline axles and put it in your rear end. There are 2 and 3 series differentials for this rear end. The 2 series is for 2.56 and 2.41 gears and the 3 series is for all others, so be sure to get the right one for the gears that you are using. The 28 spline 8.5 was used in many GM cars from '71 to '89. All of the 8.5 truck rear ends used the Governor Lock differential, which I usually don't recommend for a performance car.
New 12 bolt Rear/ questions. RObs71Nova Transmission - Rearend 1 12-27-2004 08:19 AM
70 nova questions Niapym Interior 4 05-25-2004 08:03 PM
3.73 posi for nova CombatWombat Transmission - Rearend 3 04-07-2003 02:34 PM
Traction Bar set up 72novaproject Suspension - Brakes - Steering 2 12-17-2002 02:47 PM
63 Nova Suspension Tricks - Traction BrianB Suspension - Brakes - Steering 4 10-29-2002 05:36 PM
