posi unit - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-22-2008, 09:58 PM
posi unit
I have a auburn posi unit i just got i put in in my truck and also but posi additive in it i took it out and drove it for a little bit make sure it was ok and later i put my boot in it and just one wheel hooking up.??? I jack up the rear end to check it all out and both wheels are turning. Could anyone tell me what to look for or what to do and thank you
Old 06-22-2008, 10:38 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
Boot? as in security boot?
It might just be that the posi isn't sticking together well. Is it used or new? Under high friction differences the torque of the engine will overcome the posi, but we need more details... Used or new? boot? which auburn?
Old 06-23-2008, 06:12 AM
posi unit
Sorry for not explaining the right way my posi unit is used and when i said my boot.???? i did a burn out. Also i dont know which auburn it is i do know it is a 10 bolt 7.5 Again thank you and sorry for not enplaning myself to well getting old and not to sharp thanks so much for the help you are trying to give me
Old 06-23-2008, 06:53 AM
SSedan64's Avatar
Most of the Auburn Posi Diffs use metal cones for friction instead of friction clutch plates like the Eaton Posi. I don't think the cone type Auburns require a posi additive. I may be wrong. I'm sure someone on here knows for sure.
The cones wear against the diff case for friction, once the diff case is past the wear limit it's done.
Old 06-23-2008, 08:42 AM
302 Z28's Avatar
Being that the posi unit is used...there is no telling. Unless you knew the history of the unit you should have gone through it before intalling it IMO.
Vince
Old 06-24-2008, 12:39 AM
Mat it, put it to the wood, nail it, floor it, yea, I knew what you meant. I guess the wood was from a wooden floor???
I think too you ought to have checked. Hmm, howsabout a locker???
Port or Full time vacuum cool rockin daddy Engine 129 10-05-2010 04:00 PM
Who makes best posi unit and gears elvis 66 chevelle Transmission - Rearend 6 10-31-2006 12:11 PM
posi unit for 1971 Camaro todel1223 Transmission - Rearend 2 09-12-2005 12:22 PM
posi unit and axel combo malibu68 Transmission - Rearend 4 04-11-2005 10:50 PM
posi unit identification malibu68 Transmission - Rearend 2 03-27-2005 11:57 PM
