posi unit for 1971 Camaro - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-11-2005, 12:18 PM
todel1223's Avatar
Does it matter what ring and pinion is in the car to add a posi unit? Right now there is a 10 bolt. I am looking at a 8.5 GM 10 bolt posi unit 28 spline 8.5 positraction, that had 3.73 gears on it that are now removed. Will this work or what do I need to know?
Old 09-11-2005, 10:24 PM
You need to find out if it's an 8.2" 10-bolt or an 8.5" 10-bolt. Once you do that, you need to use a carrier that is compatible with the gears you intend to use. Here's a site with some pictures of various GM rear ends:
http://www.oldsmobility.com/10bolt-tech.htm
The 8.5" with 3.73 gears should have a "3-series" carrier, used with 2.73-up (numerically higher) gear ratios. It should have "410408N" cast into it. It will NOT work in an 8.2" rear end. Any 8.5" gears that are less than 2.73 will use a "2-series" carrier, cast 410409N.
Old 09-12-2005, 11:22 AM
Hippie's Avatar
Last journal entry: HEI comparison.
Odds are it's an 8.5, my '70 Camaro was an 8.2 and my '71 Z-28 was an 8.5. The axles from an 8.2 of the same length will work in an 8.5 and vice versa but the carriers (as stated above) will not.
Port or Full time vacuum cool rockin daddy Engine 129 10-05-2010 03:00 PM
82-92 camaro posi rear end info NoEgoMan100 Transmission - Rearend 4 10-21-2005 02:22 PM
posi unit and axel combo malibu68 Transmission - Rearend 4 04-11-2005 09:50 PM
posi unit identification malibu68 Transmission - Rearend 2 03-27-2005 10:57 PM
30 spline posi unit..what axles? 383MontecarloSS Transmission - Rearend 3 03-09-2004 12:36 PM
