We're winning the case!
Hotrodders Bulletin Board > Tech Help > Engine
  #1
Old 11-24-2008, 02:30 PM
eatonde eatonde is offline
posi viton valve seals
Hey guys what advantages would these
http://cgi.ebay.com/ebaymotors/ws/e...1%3D%26_fvi%3D1
ive me over a basic thin wall uberella type?? These are the seals he recomended I use for my 062 vortec heads... Any suggs??
Old 11-24-2008, 03:19 PM
hotrodhill hotrodhill is offline
viton seals
These are a much better seal than an umbrella seal. For one the spring keeps it tight to the valve stem for less leakage, and the lower portion fits tightly around the boss of the valve guide, plus if these are the ones the heads call for I would definitely use them. I used to work for Chevrolet when these were first put out, they are an excellent seal. You can even machine the bosses on older style heads to accept these, which many people do. Hope I have helped, Hotrodhill.
Old 11-24-2008, 03:26 PM
red65mustang red65mustang is offline
exhaust valve stems get hot as hell....
the viton flueropolymer survives alot longer than neoprene at higher temp....
the spring helps insure it does make the best seal possible....
there is only a tiny contact point with the stem to squeegee off the excess oil so you want the best material for the job...that's viton
Old 11-24-2008, 05:11 PM
thanks guys
Just the answer i was hopin for
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "posi viton valve seals"
Valve Lash adjustment hiball Engine 36 05-11-2009 10:12 AM
305 engine valve stem seals pablo Engine 4 11-21-2007 10:30 AM
chevy 350 valve guide seals wiretwister Engine 3 10-17-2007 07:36 PM
351 Cleavland valve seals ImaPseudonym Engine 6 10-28-2002 03:43 PM
valve stem seals HQ Pete Engine 2 04-02-2002 12:04 AM
