positioning piston rings on piston - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-21-2009, 02:20 PM
Hello, I'm installing pistons in my chevy 350 and would like to know the right
position of oil ring and the 2nd and top rings on both sides of the motor
Old 03-21-2009, 02:30 PM
DoubleVision's Avatar
The tri position, bottom ring 6 o`clock, 2nd ring 10 o`clock. Top ring 2 o`clock.
Old 03-21-2009, 03:07 PM
I usually install the top two, with the gaps about 2.5 inches apart, centered around the wrist pin line. I put the oil seperator ring with the gap centered on the wrist pin line, but on the side oppposite the top two rings. The scraper rings are isntalled with gaps 2 inches apart and centered on the seperator gap.
But you know, I'm not sure how much it matters. Rings, and in particular, compression rings, like to move (rotate). Not uncommon for ring gaps to be lined up on dissasembly. I've been told this is more common on engines that were bored without using deck-plates.
Old 03-21-2009, 05:23 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I agree that the rings migrate around on their own.
I believe the reason for setting the ring gaps staggered when assembling is for nothing more than assuring that at start-up, the end gaps won't be aligned.
After initial start-up, the end gaps go where they go.
Old 03-21-2009, 06:09 PM
327 / 350 hp's Avatar
Hi guys,,Looking at eng from rear and looking down,/// 2-5 O`clock for oil-ring spacer end gaps.8-11 O`clock for ring-rail gap. 9 O`clock for 2nd comp ring and 3 O`clock for top comp ring..... Hope this helps..... jim
Old 03-21-2009, 06:33 PM
I agree with the others, after break in it don`t make any difference.
stroke to rod ratio jacobm99 Engine 28 12-16-2013 06:46 PM
Gapless Piston Rings - Do I Need Them? leejoy Engine 13 12-31-2007 07:37 AM
Need More Info On Piston Rings Canadian Charlie Engine 1 02-25-2006 06:00 PM
327 in 88 Truck pete379 Engine 101 01-19-2006 10:03 PM
longest rods in std deck 454 bbc?? deuce_454 Engine 11 01-30-2004 11:06 AM
