Positive valve seal advice please!!! - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-01-2007, 10:55 PM
Augusto's Avatar
From the middle of the world
Last wiki edit: How to rebuild an engine Last photo:
I know I need to machine the guides to install positive valve seals on the guides of pre-81 chevy SB heads, the problem is what are the final dimensions of the guide after machining, please don't tell me there is special tool to cut them, I don't have it and will be hard for me to get it, just tell me how the bosses should end up and I'll devise a way to machine them.
It would be great if someone knows a link to a site that explains this, with pictures better yet.
Thanks in advance.
Augusto.
Old 11-01-2007, 11:28 PM
carsavvycook's Avatar
My 2 cents worth
Wiki Edits: 3
Goodson sells a tool to cut the guides down. they have a variety of sizes available. My experience with small block Chevy's is to use a .500 or 1/2 inch cutter down just below the depth of the seal. Chamfer the top of the guide to allow a good start and seat of the seal. The diameter is going to vary depending which seal you are using. A .005 to .008 fit will be enough.
Zoop Seal coating for polished aluminum, RESULTS!!!!!!! fordSR Engine 15 02-05-2010 01:04 PM
Chevy engine doesn't fit Chevy Trans! 2000jack Engine 21 01-31-2008 11:51 AM
sbc valve seal question jw4413nv Engine 8 05-21-2007 10:05 AM
small block valve seal question, o-rings? propaniac Engine 2 11-23-2003 02:39 PM
Cam Help black66 Engine 3 05-12-2003 07:15 PM
