positraction on eaton rearend - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-02-2006, 02:20 PM
Does anyone know if you can get positive traction on an Eaton HO-33 single legger in a 59 apache pick up?An old rodder told me you could put in a Z spring and it would push the axle gear in,but would this work or is that about the same as welding the axles like on a jeep?
Old 08-28-2006, 01:51 AM
Smoke 'em if ya got 'em!
Happiness is a tight possi
What would the z spring be doing if there are no clutches in there to push on. I'll bet someone makes a posi for that, if not, I put a 78 firbird rear end in my '59, it is the exact same width, easy to get gears and posi for, makes it a 5 on 4/34 bolt pattern too for better rim selection. Try 4 wheel parts wholesalers, they prolly gots one.
I need some input on putting a Ford rearend under a 1972 Dodge Dart onebadmerc Transmission - Rearend 7 12-21-2005 10:30 PM
Hotrodders Knowledge Base: Transmission - Rearend Jon Transmission - Rearend 0 11-26-2005 06:23 PM
rearend for a Model A 30coupe Transmission - Rearend 10 11-25-2002 08:04 PM
measurments for a rearend 50chevyfastback Transmission - Rearend 2 10-04-2002 12:19 PM
