Possible 383 build, need a little Insight /Advice - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 02-19-2013, 01:00 PM
vinniekq2's Avatar
Or if you want both a tad more torque and would love to rev up like the import guys and the crank you have is in good shape,,,prefer forged,,,build a 361 hi rev.if you rev 72-7600 there is 540 hp plus available.
your heads would need to flow around 315 cfm and that could pull 8k.
you need a good solid roller and matching valve train
  #17 (permalink)
Old 02-19-2013, 01:09 PM
vinniekq2's Avatar
12-705-8 - Magnum
I might even use a cam like that but change it to 108 square
looks like a very nice moderate street cam
Im not arguing with hcompton,just saying I personally would like a little more RPM potential.
that cam would work excellent with AFR heads or any head that has very good exhaust flow
  #18 (permalink)
Old 02-19-2013, 01:10 PM
painted jester's Avatar
TAKE A KID TO A CAR SHOW
Last journal entry: Wifes 79 comeing together!
Vinnie 383s are like cookies from the same cutter, everyone has one!! LOL And a high rev small block is something to brag about Like Devils food cake!
Jester
Not trying to change your mind 4srs just steeling your thread for a moment Sorry
  #19 (permalink)
Old 02-19-2013, 01:20 PM
Originally Posted by hcompton View Post
They Will?? no they take all the same things to make big power. 700hp from an import engine is amazing if its an NA 4 banger build. That will be a fully let out 10K rpm or better engine. Like 20K worth of goodies.
Most imports cant make more than 300 hp without boost. Do all the same things to the 383 and you will be over 1000hp. Only real difference is the heads for chevy are worse stock but you can buy good ones.
Compton
I was waiting to see who would post on that claim I thought sure Vinnie would be first chomping at the BIT LOL
Jester
  #20 (permalink)
Old 02-19-2013, 01:29 PM
all4sr's's Avatar
450 or bust
continuing on the lines of what Painted posted.If you plan to race against these imports,have you considered stealing some of their technology? toss a couple turbos on your V-8 and your tune will net over 800 HP and torque and smiles per mile.
I don't want boost, I'd rather stick with N/A, as far as Running them go, didn't mean that the ones I want to run are the 700hp ones, lol, more like the 350/400hp Hondas and BS that think their car is gods gift to man.
Originally Posted by painted jester View Post
The stroked small blocks depending on kit or your crank and rod choices interferences are encountered Like rods contacting cam lobes ETC, Plan your build very carefully! LOL Did you contemplate building the 350 for high RPM or do you need the extra torque of the 383 for your application?
Jester
The Block had already been bored .030 over, so I just kinda wanted to build a 383 based off of expieriences I've had with Other friends that have them.
Obviously, I didn't mean they could do that N/A. They take SC,TC, or Spray to get there. I've built and had my hands on quite a few 500+hp Imports. I was more so refering to Clearencing a block, blueprinting, etc. If it is a Strict Race motor, then yeah, all that would be done, but alot of the 7/800hp imports running around are just built, put together, and Dyno tuned. (and no, i'm also not saying they don't change fuel supply, trannys, or rear ends).
12-705-8 - Magnum
Jester
It's all good, Like I said, I'm open to opinions and advice. It's just my first v-8 build, so what is good for what when it comes to what I want with a v-8, is something new to me, and needed some 'direction', if you will.
  #21 (permalink)
Old 02-19-2013, 01:33 PM
Jester
383, 500hp, sbc
Need advice on a 383 build Sohcnick Engine 8 06-25-2012 01:14 PM
383 SBC Build advice Andy Sweeney Engine 5 10-13-2011 05:25 PM
350 engine build not as power as hoped... insight? Fry Engine 19 08-10-2009 03:12 PM
Wanting thoughts or insight on 383 street build scarecr0w Hotrodding Basics 12 01-27-2009 11:30 AM
need advice on 383 build up mxbadboy03 Engine 4 10-12-2007 08:33 PM
